ESP retro-fit
- Currently Drives:: 57 plate 1.5dci 106 eclipse grey
ESP retro-fit
Greetings all,
I've just prised off the panel holding the cruise control, panel light dimmer and headlamp leveller switches and noticed a blue multi-pin connector wher the ESP switch would be. Obviously this plug is not connected to anything, and I was wondering whether ESP could be retro-fitted to the car with the addition of the correct switch.
Can this be done?
Will Renault supply the switch?
Will the brains of the car need to be re-configured?
Grateful if anyone could shed some light onthis please.
Many thanks.
SK40 (should be SK42 now...doh!)
Can this be done?
Many thanks.
Re: ESP retro-fit
Needs sensors etc. too - not feasible, unlike cruise control.
Re: ESP retro-fit
I agree, would probably involve serious costs, otherwise probably more people would have already retro fitted this option.
Re: ESP retro-fit
huge time gap here but..............
as all megane 2's have ABS the esp system uses the same wheel sensors. i.e the one sensor does both jobs all you should need is the ecu reprogrammed and the switch. there may be a control module but i can't see it being a major job.
i'l have a look at the wiring diagrams for the with and without and highlight any mayor differences
- morganjake1544
Re: ESP retro-fit
Isn't there a yaw sensor to detect lateral G force and a sensor to feedback steering wheel input ? I think it would be cheaper to buy a new car.
- direstraits
Re: ESP retro-fit
You would need a different ABS/ESP hydraulic modul, over 1000 €, Renault would charge even more. You need also a yaw sensor (under seat) 400 €, and the sensor on the steering wheel €€€. Then you would need someone with CLIP to put everything together and reprogramme the ECU (if not the new ECU). Very expensive job, IMHO.
Re: ESP retro-fit
Ok guys, im on this one now.
- Ive got the ESP button (3 buttons panel, not possible to find the button alone..)
- Ive got access to CLIP
- Ive bought a hydraulic module for usage with ESP(to replace the normal ABS module) on the scrapyard
2nd part:
- Steering angle sensor, is already fitted in the steering? i dont find anything on the Renault spare parts (official webapp for identify and order spares). Maybe the steering column is the same on every car, then its used or not .
- yaw sensor, Gforce sensor, what ever you want to call it, as far as i could find all cars use it, Ref: 82 00 074 266, its the same for cars with only ABS or plus ESP.
So, can anyone confirm this info? I appreciate your help, it may be more easy to retro-fit this then it seams.
Other info is the ref for the ABS module w/O ESP: 7701067590 or 7701062932, with ESP Ref. 8200355248 (at least this ref, i think there is at least one more ref)
2nd part:
Re: ESP retro-fit
Where is the megane electrical schematics ? ive been searching the tehnical manuals and notes but i cannot find the schematics...can anyone point me the right direction?
cheers
cheers
- MéganeDynamique
- Currently Drives:: Renault Mégane 2.0 VVT Dynamique Sport Hatch
Re: ESP retro-fit
I had a look behind my panel and found this:
My car has neither cruise nor ESP... so which one is this connection for?
Re: ESP retro-fit
Google for Megane II X84 NT8220A c 02_09_2002.rar, Megane II X84 NT8206A.rar, Megane II X84 NT8222A.rar, Megane II X84 NT8227A 2003_01_01.rar, Megane II X84 NT8228A 2003_11_17.rar or Megane II X84 NT8266 28-06-2004.rar depending on what year/model you are interested in.
tomalamix wrote:Where is the megane electrical schematics ? ive been searching the tehnical manuals and notes but i cannot find the schematics...can anyone point me the right direction?
cheers
- Anthony
Re: ESP retro-fit
MéganeDynamique wrote:I had a look behind my panel and found this:
Phase 1 megs came fitted with the full wiring loom, even if they didn't have all the options.
- MéganeDynamique
Re: ESP retro-fit
Yep, I've been able to add heated seats and tyre pressure sensors so far
But any idea which one of the two this connector is for? I'm not sure whether it's cruise or ESP.
Re: ESP retro-fit
AlexB wrote:Google for Megane II X84 NT8220A c 02_09_2002.rar, Megane II X84 NT8206A.rar, Megane II X84 NT8222A.rar, Megane II X84 NT8227A 2003_01_01.rar, Megane II X84 NT8228A 2003_11_17.rar or Megane II X84 NT8266 28-06-2004.rar depending on what year/model you are interested in.tomalamix wrote:Where is the megane electrical schematics ? ive been searching the tehnical manuals and notes but i cannot find the schematics...can anyone point me the right direction?
cheers
thanks alexB, i'll search for that
cheers
Re: ESP retro-fit
Hello.
I'm new in this forum. So far I have found a lot of useful information on this site. I'm wondering if there is anyone who have done this (retrofit esp).
This would be really great news. So far I have access to clip, I have wiring diagrams for megane 2, all I need is to look for part number on abs unit to locate if there is esp support and if not replace it, connect the esp off button and ... ?
any help will be useful or any steps already made to achieve retrofitting.
Many thanks MT
Many thanks MT
Re: ESP retro-fit
Hi all,
I'm new to this forum and I'm interested in retro-fitting ESP on my Laguna II.
Did someone successfully finished that process?
