Hi All,
Just got myself a Megane 1.5dci dynamique last week. Was cheap but came with a couple of problems, heater only works on speed3, assuming it the resistor pack so will be replacing that. Main thing is that speedo worked fine for 2 days, now it won't sit at 0 when standing still. Sits at 20mph, so when doing 30mph according to the sat nav, the speedo shows 50mph? I'm guessing the clocks need replacing?
Any tips would be much appreciated.
Speedo Issue
Re: Speedo Issue
change the speedo from a scrap yard one is the cheap and best option.
about the blower is a well documented issue here in the forum, make a search around and you will find more help, i think it even includes ways to repair it instead of buying a new blower
good luck
good luck
