Sorry guys I need a bit of help.
My own fault really, I haven't started the car since Dec 23rd, went to start yesterday and it would not spark into life - but it was very cold. Eventually I drained the battery and said that I would jump start it today. I tried to jump start today and only succeeded in draining the battery.
Now when I get in the car nothing works apart from horn and radio, no lights no dashboard no blower and so on, I am going to take the battery off and charge overnight...
Would draining the battery so low cause a fuse to blow? Hence the total lack of response opening the doors - oh yes central locking or hazards will not work also
Any help would be appreciated - I need to get this up and running again before Monday.
Oh yes and my missus has just stormed out in a paddy as her new phone doesn't work and I am too busy with the car to help her speak to another Indian call centre - please help and make it a positive start to the New year
Megane 1.5DCI - electrics dead
Re: Megane 1.5DCI - electrics dead
Hi again
I have had the battery off and charging overnight will try this a little later.
In the meantime I have connected the wife's battery to my + and - leads, nothing lights up as I open the door - but the radio does come on again.
Is there one main fuse that controls the entry lights dashboard and Start/Stop function?
Hopefully it is just a blown fuse or it will be going to Megane heaven, as it has other issues.
All because I forgot to turn it over each day
Any help would be greatly appreciated
there is a main fuse on the top of the battery, not sure if it feeds the entire besides some functions like the radio and a few more small things, its not a common fuse, but you can find t on the market
Cheers tomalamix
I borrowed a multimeter and checked it before replacing
It was that, I managed to find a replacement for 1.60GBP.
They are called MIDI fuses 30, 40, 50 amp - I had to go to a specialist auto electrics retailer though.
I have had to change battery though so not all that cheap damn this cold weather and rather old car
im glad you make it...it was not to expensive too, for this car that price is very very cheap
