injection fault
- Currently Drives:: Megane 1.5 dci expression estate
injection fault
hi im new to this so here goes,,
i have a megane exspession 1.5 Dci estate
its showing injection falt and not starting but if i leave it for a few min it starts.it says it a couple of times when going up a hill but im more concerned about it not starting, im going to renault this monday 1 sep 14 , and its costing me £ 60 just for then to do a diagnosic..
ive already had the egr valve replaced recantly due to another problem.
any idears please i haven got the money if its the injectors,,
thank you
debs
thank you
debs
Re: injection fault
Could be fuel filter or maybe glow plugs had the fault with mine and it turned out to be the fuel filter
Re: injection fault
Ok thanks. Hopefully the diagnostic will say that on mon
Re: injection fault
Is it expensive to change the glow plugs or filter...
Thanks debsx
Thanks debsx
Re: injection fault
that is a thing that started to happen more and more often or it was suddenly?
Re: injection fault
More and more..@
Ive already had the fule filter changed..i forgot lol
Im not sure if i ahould take it to Renault now as last time they said i needed things done and when i then took it somewhere else it didn't. .please help i don't know what to do. ...
Thanks debsx
Thanks debsx
- Stranger
- Currently Drives:: BMW X1
Re: injection fault
Find yourself a good auto electrician for a diagnostic, if you don't know one ask friends, work colleagues etc, check Yell.com for your area and look at the good garage scheme.
Re: injection fault
what is the mileage of the car?
well, just to cut through, if the mileage is above 150000km go to a Renault main dealer and ask them to test your HP fuel pump. It seams that it started to go away and is not easy to test it without a dummy plug they have there (i wish i knew the schematic of that plug, you could to this test outside the dealer with it...), they connect it to the HP pump and then try to start the car. the car will not start but the pressure can be read on the CLIP software. The pressure must reach a certain value if its good, if not there you'll have your fault, HP pump wrecked. if this fault is confirmed they will try to sell you the pump, injectors, pipes, bla bla bla because of metal chips contamination (from the pump), they are right, it will be contaminated but its very expensive to do change everything. ive seen several wrecked pumps swapped and maintaining everything else and they work just fine, swap just the fuel filter.
good luck
good luck
Re: injection fault
Hi sorry for not replying sooner did renault do your fuel filter or just a normal garage. Only reason I ask was that I had a problem because the garage used a filter that's was not a renault one and when they changed to proper renault filter I had no more injection faults
Re: injection fault
Also do you get injection fault when you accelerate quickly? Also any garage should be able to test glow plugs there is a link on this website that shows you
Re: injection fault
I had tje fuel filter changed by a small garage. Yes the lights are coming on whwn im just driving but now its taking at leSt 6 attempts to start. .kwick fit said it might be fule pressure control value. ..its booked in Renault for mon
Re: injection fault
How did you get on at the garage?
Re: injection fault
hi 2 injectors needed changing so i had all 4 injectors done and filter,, cost £690.00 car stars fine now
hopefully nothing else goes wrong.
THANK YOU ALL xx
THANK YOU ALL xx
Re: injection fault
Was the fuel filter replaced before the fault? It can be that dirt was introduced into the fuel line during the job, which caused the problem.
debbiet wrote:More and more..@
Thanks debsx
