hi all,
anyone have any pointers as to how to replace a handbrake cable on a 2003 1.5dci 3dr megane?i can remove it from the brake caliper,but it goes through the body into the handbrake lever in the car.does this pull out (after releasing from mechinism) or what?
cheers!
handbrake cable
Re: handbrake cable
Open the cubby hole above the handbrake, then un-clip the piece of trim that the levers go through - up and forward. Behind it are the adjustment nut and balancing bars.
Re: handbrake cable
thanks dave,
ive done that but my question is, does the cable pull out after ive disconnected it from the lever/adjustment bar inside the car?
cheers.
cheers.
Re: handbrake cable
Haynes says: unclip from calliper, detach from balancing bar, follow the outer cable from the calliper to the hole in the floor, disconnecting any clips or mounting brackets as you go. Remove from under car, replace... Sounds like a plan!
Re: handbrake cable
cheers dave,
i havent got a manual for the car(ill have to aquire one)its my daughters car and i didnt want to just try and yank the cable out incase there was another clip or attachment i couldnt see.
thanks for your help.
cheers!
cheers!
Re: handbrake cable
Let us know how you get on!
Re: handbrake cable
cheers dave,
it might be a while as she uses it everyday and i need some time off? to do it!!!
ive put a bid on a well known site for a workshop manual(cd).
do you know if these are off much use?
cheers!!
cheers!!
Re: handbrake cable
Ah - at the top of this forum there is a sticky for the workshop manual pdfs (straight from Renault). They do sometimes imply a certain amount of familiarity with the cars. But if you are sensible, you won't have any problems...
Re: handbrake cable
cheers dave,
thanks for your help!
- Currently Drives:: 2003 Megane Tourer 1.5dci in White
Re: handbrake cable
boru wrote:hi all,
cheers!
Hi Boru, did you ever get the handbrake cable sorted, how did you manage to fit it ?
2003 Megane Tourer 1.5dci 80hp
- Currently Drives:: 2005 Renault Megane 1.5 DCI 106 Sport Tourer
Re: handbrake cable
Did mine in the weekend... basically all you do is unhook it from the outside of the car.. get your fingers inside the back of the central cubby hole and loosen the balancing bar (13mm spanner) enough to disconnect the cable from the balancing bar yank the cable from the outside of the car (where it enters the car underneath).. (the cable inside the car is routed through a metal pipe from the outside of the car to the inside of the car so the cable will route itself in to the car. up to the point where you can connect it to the balancing bar).. i would connect it to the caliper first then the balancing bar and then tighten it up on the balancing bar inside the bar.
Users browsing this forum: No registered users and 64 guests
